Hello everyone,
I recently started trying to build the "Clarifier" onboard pre-amp, so that i could just plug in my headphones without using an external amp.
Another reason for not using an external amp is because is don't have one yet.
To test if my pre-amp is working i use Audacity, the problem is that it does work when i plug it in on my computer but doesn't work when i just plug in my headphones..
This the back view of the layout, I added a DPDT switch so i could switch between clean sound and the pre-amp.
"A" is connected to the pickup switch. the clean signal and the pre amp'd signal are both connected to the same output jack pin ( not sure if that is a problem )
Any ideas what the problem could be ?
Some photos :
http://imageshack.com/a/img540/1610/P4XtAD.jpg
http://imageshack.com/a/img661/2936/qc3rpN.jpg
http://imageshack.com/a/img661/3971/HEbMuz.jpg
http://imageshack.com/a/img540/614/JSJCOc.jpg
Some photos :
