Quality potentiometers
  • Quality potentiometers
    I'm in the process of gathering all the parts for my amp. Most everything
    has been decided but the potentiometers are giving me a bit of trouble.
    Is there a big difference if I use 250K linear pots instead of log tapers
    for the bass and treble controls ? I've read some people say that they
    prefer linears. Fender's audio tapers were 30% which is pretty close to
    linear.
    I originally wanted to use Bourns 3852 cermet pots but I can't find a
    source.
    So I've decided to go with pots made by Precision Electronic Components
    sold by Digi-Key, these are MIL style K/RV4 :
    http://www.precisionelectronics.com/...tyle%20RV4.pdf
    These have "hot molded carbon elements". Is this just regular carbon ?
    Anyone used these pots ?
    All the values I need are available except the 4M and 10M reverse audio
    for the vibrato. What would be a good choice for these ?
    I also tried to source various Clarostats, they look good, but I can't find
    them in log tapers anywhere in single quantities.
    I've spent hours searching for pots. Any help would be appreciated.
    Paul P
    I get Clarostat pots from here:
    http://westlabs.com/
    He has 250k in both linear and audio tapers.
    I doubt you'll find reverse audio tapers anywhere. But you can probably simulate them:
    http://www.geofex.com/Article_Folder...s/potscret.htm
      Ted Weber has 3m and 10m reverse audio pots.
        Thanks for the help.
        Are Ted Weber's pot's any good ? He also has the 350k-70k tap
        treble pots which would better fit my circuit. At 2.00$ each I'm
        a bit worried that they're not the highest quality.
        For the 4M and 10M pots I've been thinking about using a 1M
        audio pot with a rotary switch to switch in a variable number
        of 1M resistors. Kind of kludgy but it would permit me to use
        a quality pot.
        Angela Instruments has some NOS Clarostats that are in the
        proper range but they're linear. Would this make a big difference
        in a vibrato circuit (speed and intensity) ?
        Paul P
