FilmOsound Amp conversion
  • FilmOsound Amp conversion
    I have a 385 Bell & Howell projector amp which I'm recapping. In the process a clear light bulb part #27777 fell off. It hasn't effected the amp and I was wondering if anyone knows what it does in the circuit. It's about the size of a Christmas tree mini lite. On the drawing it is listed as NE-2 and it is covered with a black nylon tube.
    NEON NE2 USA - NEON/NE2 USA - neon glow lamp light bulb lamp - donsbulbs - light bulbs lamps valve valves tube tubes
    Should I be concerned running the amp without it.
    Thanks
    Raja
    Raja, The lamp you mention is likely part of the optical sound circuit........Detailed information about these amps is available at Film-Tech.com.Search the manuals section for 16mm projectors.Your amp is among those listed. Regards, Steven
