I think I have parasitic oscillation in my latest amp build - a 6AK6 push-pull amp.
It has a fairly loud hum - not tons, but enough to be annoying. The amp played fine for several months and then began to have scratchy distortion on top of notes played with the volume turned up.
I hooked up the scope and found a 40 mV PP sine wave (almost) at about 100 Hz (5 x 2 ms) on the cathodes of the output tube (fixed bias), and a strange 6 V P-P high frequency (2.5 x 2µ) sin wave with varying phase before the grid resistor of one of the output tubes. This happens only when the volume is at about 8, which is about where the scratchy distortion occurs.
I've attached a schematic.
I used the chopstick test and re-soldered almost everything, but it's still there.
I've also ordered 6AN5's to replace the 6AK6's, which many say can't take more than 180 volts (this amp has about 270).
It's also been mentioned that the power supply could use one more cap to separate the PI and preamp supplies ... could this be it?
It might also be the grounding.
The AC ground (green wire), power transformer (CT and heater CT) and power supply ground from the board (black wire) are all soldered together to a standoff on one of the transformer bolts. The preamp side of the board is grounded through the pot to the chassis.
I'm not sure how to proceed and am seeking your advice!
Thanks
Ron
Here's a photo of the chassis (it's the Dyno Tweed)
Thanks
Ron
