Yes, I did, thank you.
I solved the problem eventually. I was under a deadline but the owner said I could hang onto his amp longer and with no real rush on the repair, I found the source of the problem. In the reissue Princeton Reverb amps, taking them apart and then putting it back together multiple times creates extra problems with the inferior wire they use from the circuitboard to the tube sockets and various other components. Sometimes the faults are hidden under silicone.
Having trouble getting the reverb to work on a Fender Princeton Reverb amp - Reissue
Did you try connecting a speaker to the reverb send jack?
This is actually the 8 Ohm output of a little power amp.
So if you're getting speaker sound the reverb drive stage and transformer should be fine.
- Likes 1
Leave a comment:
Hi All,
Thanks for the replies. Tom, thanks for the reverb transformer data.
I keep a virgin reverb tank on my bench (Fender tube amp reverb spec), never been in an amp, just for testing situations like this. I also have a new set of RCA ended cables, again just for testing, and they did not make any difference in the reverb circuit of the PR-RI amp, still no reverb. But I went one better - I took out the PR-RI reverb tank and mounted in one of my numerous Fender amps w/ reverb where it worked perfectly fine. I did the same with the reverb cables in the PR-RI and they worked perfectly as well. And, of course, I did the ohmage measurements of the reverb tank and cables from the PR-RI and they measured as expected for working, good condition tank and cables. I eliminated these components as the source of the fault in the reverb circuit.
- Likes 1
Leave a comment:
Maybe this is one of those happy accidents where they bought so many of the initial supply, they didn't mess with the circuit for many years, establishing the classic Fender reverb sound.
- Likes 1
Leave a comment:
Originally posted by g1 View PostI think he misunderstood the first sentence quoted.
("I have seen quite a few Fender amps that had reverb transformers that were much older than all the other dated coded parts in the amp.")
Leave a comment:
Leave a comment:
Originally posted by Helmholtz View Post... Leo didn't have a reverb amp before 1963 (first one being the 1963 Vibroverb), it's unlikely to find an older than 1963 Rev. transformer.
Leave a comment:
Originally posted by Tom Phillips View PostI have seen quite a few Fender amps that had reverb transformers that were much older than all the other dated coded parts in the amp. My theory is that Fender made a very large quantity buy of the Blackface era reverb driver transformers and it took a few years to use them all up. The transformer used for the data measurements that I posted was installed in a 1966 Princeton Reverb amp.
But as Leo didn't have a reverb amp before 1963 (first one being the 1963 Vibroverb), it's unlikely to find an older than 1963 Rev. transformer.
- Likes 1
Leave a comment:
Originally posted by Helmholtz View Post1963, wow! Must have been from a very early Fender Reverb amp, maybe even from a brown Vibroverb?
- Likes 1
Leave a comment:
1963, wow!
Leave a comment:
Originally posted by Helmholtz View PostYour table shows PT measurements...
Thanks for the heads up.
Fixed.
- Likes 1
Leave a comment:
Originally posted by Tom Phillips View PostHowever, I've attached a set of data that I collected using a working Fender reverb drive transformer so you can see the typical measurements.
I'd like to add that a transformer may have shorted turns not showing in DCR, but still killing the output.
So the speaker method is more reliable.
- Likes 1
Leave a comment:
Originally posted by Bob M. View Post...Any help on testing this reverb transformer is appreciated.
Thanks, Bob M.
In addition, I recommend that you verify that the reverb driver transducer in the reverb tank is working property and is connected properly. I say this because both transducers in the spring tank will produce the crashing sound but only the drive (input) tank transducer will drive the springs hard enough to produce the normal reverb sound. The point is to make sure that the tank isn't hooked up backwards.
You can also measure the DC resistance of the tank transducers with the tank disconnected from the amp.
The Input (Drive Transducer) should measure a little less than 1 Ohm and the Output (Recovery) transducer should measure around 200 Ohms.
Tip: When measuring the Input transducer, make the measurement right at the tank connector and make sure that you subtract the resistance reading you get when you short the meter probes together.
You should also Ohm out the reverb return cable itself to verify that it's not the problem. Test for continuity end to end and verify the inner & outer conductors are not shorted together.
- Likes 1
Leave a comment:
The transformer delivers at around 15 Ohm impedance so connect a test speaker to it and listen if you have not got access to an oscilloscope.
- Likes 1
Leave a comment:
Leave a comment:
