Posting this because there is very little information about fixing this amp on the internet. I got this non-working amp really cheap, even though I usually avoid Egnater amps because of the power transformer issues they had on some of the older models. Amp powered up but had no sound other than very low white noise and channel switching was not working. Pulling the tube covers I saw that the preamp tubes were not glowing (but PI tube was). I suspected that the preamp tube heaters were on a 12VDC supply and that had failed, which could also explain the channel switching not working. There are no schematics available for this amp, but I looked at other Egnater schematics and found the Vengeance seems to use a similar scheme as the Renegade 65 for gettng the 12VDC. There is a MJE3055T transistor that is mounted to the chassis that is the workhorse bit of the regulator circuit, and that was not passing current. Replacing that transistor got the amp back to working. That transistor gets quite hot so I made sure to clean off the old thermal paste and apply new to all mounting surfaces of the mica insulator and the small aluminum mounting block. I did note that there seemed to be an extra mica insulator on the failed transistor, I wondered if that was there by accident (easy to miss since they are clear and thin) and caused the failure since there probably wasn't thermal paste between the two insulators.
Pretty easy fix since the transistor is mounted on the chassis and wires to it have a molex-ish connector to the board.
Anyway, now I have this semi ridiculous 120W high gain tube head which I don't really have a use for but is pretty fun to rock out on.
Renegade schematic shared for reference on the 12VDC supply. Note they call it a 2N3055 transistor on the schematic (and the board) but the part really is the TO-220 package MJE3055T.
