I come begging again...
Most of the time these amps present me with a pretty straightforward and easily cured set of problems, but this one is really challenging me.
So what we have is a Peavey Classic 30, black "tweed" covered, serial #10831049. The reverb will take off and start howling at any setting over about 6 on the reverb control. The offending resonant frequency is close to 100Hz. The tank is a long Accutronics (too long?) marked 4EB2C1B, making it a type-4, 600 ohm input, 2250 ohm output, medium decay, output-grounded, no-lock, "horizontal open side down" mount. Drive & recovery are both via op-amp circuitry in this amp as many of you probably know.
First thing: can anybody tell me if this is the correct tank for this amp? It sure is a tight fit in that cab...
Assuming "yes" to that question has anyone encountered and successfully cured this problem on one of these amps, and if so how?
Pulling the tank out and holding it away from the amp certainly cures it as one might expect (hardly a long-term solution). The drive & recovery circuitry seems to be functioning correctly as per the schematic, and I have done the usual solder retouch at all the common spots.
Things I have tried:
Thanks guys -
Mark
- Added cardboard under tank inside of bag (there was none present as found).
- Tried inserting a piece of foam under and/or over the tank.
- Mounted the tank loosely, tightly, screws through tank grommets (as found), and screws through bag only.
- Experimented with various caps in series with the tank output in an effort to reduce low frequency response (this really didn't work very well).
- After determining which spring in the tank seemed to be the offender (touching it damped the oscillation) I even removed a bit of its length in an effort to change the resonant frequency.
Thanks guys -
Mark
