DeVille no Reverb
  • DeVille no Reverb
    I am sure that it is the opamp that is causing my reverb not to work. The problem is when I go to Mouser.com and I look up a TL072 or a 4558 opamp, there are so many different choices. How do you know which 4558 to get????
    A 4558 op amp is just a dual 741. An op amp is an op amp. You will see LM4558, JC4558, etc. It just depends on who made them and when. NEC, Texas Instruments, whatever. If you have some old junk stereo chassis (or anything for audio from the same era really) laying around there will probably be a bunch of them in it to scavange.
      And a TLO72 will work fine in place of a 4558
        Don't overlook the reverb pan itself. The newer ones have a high failure rate. Remove it and check the drive/pickup coils with a meter. If those check out, then proceed to the op amps.
          If you are getting a 4558, then I would select the lowest cost one. Like olddawg says, the first letters merely identify the manufaturer. And the letters after usually describe the package - size, shape, material. You want one in a DIP package, not the SOIC or other surface mount shapes.
            Thank you so much guys. Great Info!
              +1 on this advice, I recently replaced the pan on a Carvin Vintage16. The send coil measured open and the connection was fine, right down to the coil itself.
              casinolevant levant casino
