Gents,
I am presently restoring a 1965 twin in pretty rough shape. With the power tubes removed, I am getting only -1.5V of bias voltage. Turning the bias pot varies this slightly, but it is still in the same low range. The amp powers up with the tubes and plays at very low volumes for a little less than a minute and blows the fuse.
I have replaced the filter caps, the cathode bypass caps and the bias cap and double checked orientation at least three times.
Four of the pots were frozen, so I replaced all of the pots (one at a time) and double checked the wiring. I will double check my wiring again.
The voltages from the power supply transformer are good as are the voltages downstream from the rectifier diodes.
The voltages on pins 1 and 6 on the phase inverter tube socket are running high at 340V each. The voltage on pin three of the rectifier tube is low at 67V.
Any help would be appreciated.
