Source for A1M 12MM miniature pot
  • Source for A1M 12MM miniature pot
    I have an egnater amp that needs an A1M pot. I purchased a 16MM miniature from mouser that looked like an exact match, but too big. They do carry a 12MM but use a 'D' type shaft instead of knurled.
    So, what I need: 12MM (maybe 14MM?) 1M audio pot PCB mount, knurled shaft.
    Anybody have a source?
    What part number did you get from Mouser? I thought the Egnater used 16mm pots from what I remember being inside of mine.
    Jerry
    FJA Mods
    FJA YouTube
    FJA Facebook
      I've got an email into them right now. They told me awhile back I could find replacements parts at Mouser. I purchased the 16MM since they appeared to be the right size, however they're not. Too big, the case/body is bigger, the pins don't line up with the PCB holes, and the shaft sits higher because of the bigger body. The shaft length and diameter are the right size.
      I'm assuming 16MM, 12MM, size refers to the diameter of the case/body?
        If they can't or won't actually supply the part to you, ask them if they can provide a stock number at Mouser. Tel them you can't seem to spot the correct part there.
