Hi All,
Something's got me really stumped on my bench and I'm hoping some of you can help me out.
I'm working on an Earth G2000 guitar head, which is basically a fender twin rip off. However, I have completely changed the output section to a Marshall set up with EL34's. Brand new PT via MetroAmp. The bridge rec and entire bias circuit is brand new. Also brand new are the 5.6k grid stoppers, the 1k5Watt B+ resistors, and the 220k bias feed resistors.
For some reason, I can not get the voltages to match via my bias probe on V7 and V8, however the voltages measured on each pin of the tube socket while the amp is on, tubes are in, and idle are all correct. Really stumped. Here are the pin voltages for each tube, and also my bias measurments. Any help would be greatly appreciated!
Amp On, Tubes in, Idle
V7
1 0
2 3.3 VAC
3 495VDC
4 491VDC
5 -50VDC
6 491VDC
7 3.3VAC
8 0
V8
1 0
2 3.3 VAC
3 495VDC
4 491VDC
5 -50VDC
6 491VDC
7 3.3VAC
8 0
V9
1 0
2 3.3 VAC
3 495VDC
4 491VDC
5 -50VDC
6 491VDC
7 3.3VAC
8 0
V10
1 0
2 3.3 VAC
3 495VDC
4 491VDC
5 -50VDC
6 491VDC
7 3.3VAC
8 0
Via Weber Bias probe on
V7 Vp = 481VDC, Ik = 17.1
V8 Vp = 476VDC, Ik = 15.4
V9 Vp = 500VDC Ik = 24.6
V10 = 500VDC, Ik = 18.1
Where is the magic drop in Vp on V7 and V8 comin' from??
Thanks in advance!!
V7
1 0
2 3.3 VAC
3 495VDC
4 491VDC
5 -50VDC
6 491VDC
7 3.3VAC
8 0
V8
1 0
2 3.3 VAC
3 495VDC
4 491VDC
5 -50VDC
6 491VDC
7 3.3VAC
8 0
V9
1 0
2 3.3 VAC
3 495VDC
4 491VDC
5 -50VDC
6 491VDC
7 3.3VAC
8 0
V10
1 0
2 3.3 VAC
3 495VDC
4 491VDC
5 -50VDC
6 491VDC
7 3.3VAC
8 0
Thanks in advance!!
