A good friend dropped off a deluxe reverb from (I guess) '79. Its got the line out & the volume boost push Pot.
I've got building experience with the blackface version but this one Silverface is extremely loud at low settings. I mean: in vibrato channel I measure slightly over 30 watts output when its on 3. Same counts for the normal channel
Bias of the 6V6s are on 21ma, B+ voltage is on 440-450.
I did notice the plate voltages of the preamp were way higher than the blackface versions, so I did change the 2.2K filter resistor to 10K -> All plate voltages and bias of the preamptubes (V1-V5) seem to be very close to the blackface area but didn't solve the early loud "problem"
Phase inverter
I guess the problem might be at the phase inverter
http://users.telenet.be/pierssens/SF/DSC00072.JPG
Pin1 voltage: 223DC
Pin 6 : 201DC
PIN3,8: 64DC
330K resistors at the grids
680 ohm resistorat the cathodes (there is 2.1DC over this resistor)
When modifying the phase inverter to Blackface specs will I have a smoother volume control?
Thanks for your input!
Phase inverter
Pin1 voltage: 223DC
Pin 6 : 201DC
PIN3,8: 64DC
