Hi,
I'm new here. I have problem with my 5150 Combo. The amp is so loud, cause the post pots is can't uses. Also the eq and the reverb. I'm only can use pre pots(both channel), resonance and presence.
Herewith the quote answer from enzo from faulty peavy 5150 mk 1 combo
I have check all control ground, and the share ground is OK.
1 think confuse me, the post pots if measure on the board, is only read 23 Ohm (the pots is 1 M), but if I'm pull out the pots from the board, the pots read 1 M by DMM.
Any another suggest with my problem?? THX
Originally Posted by Enzo
Hi, welcome to the forum.
It would be a good idea to start a new thread for your amp instead of adding on to the end of this old thread. You will get better response, especially since your problem is different from the original post problem.
All those controls in your amp share the same ground return. I think your ground connection to them has been lost. First, make sure the jack nuts are tight on the FX loop jacks, they are involved in grounding that section. But what I fear is the problem is a broken jumper wire.
Please be careful inside this amp, the voltages it uses can KILL YOU.
With power off, the amp unplugged from the wall, and power supplies discharged, look at the circuit boards. There are three sub-assembly circuit boards that are connected together with a row of short bare wires - "jumper wires." One row of jumpers connects the control panel board to the small board with a couple relays on it. Then another row of jumpers connects that relay board to the preamp tube board. Use a small tool of some sort and get under each and every little bare wire and gently tug on it. If any come away, it was a broken wire. And that would need repair.
Thx Enzo, I'll try to check the ground and the jumper.
Sorry I'm wake up the old thread. I'll make a new thread after this.
