My name is Rob,
I'm a guitar player, a hobbyist builder/tech, and like you all, a valve amplifier enthusiast.
I own a handful of tube amps, but the ones I use most often are my Ampeg B25's. I have one from '68 and one from '74.
I play my main setup 95% of the time, though I really should start playing my other amps more often. This is the Ampeg's setup. 60's Marshall basket weave 4x12 loaded with some unusually warm and well aged Vintage 30's with which the original Greenbacks were replaced. I have that wired in parallel at 4ohms. I leave a dummy cable plugged in to use the 8ohm tap to compensate for the objectionable impedance mismatch. I use a Box-of-Rock overdrive and boost pedal for little kick in the preamp.
Whenever I practice or play a show, I usually play in the same volume range, which is pretty high. Hopefully this doesn't come off ignorantly, haha, I just love playing loud and pushing the amp. Ear plugs are awesome. I run the boost sometimes, but mostly the OD with flat controls 12oclock. I run the amp at about 5 plugged into Channel 1's Normal input. I play heavy music, like hardcore, punk, metal. I'd say I play the amp about 1 or 3 hours a day full throttle (playing frequent shows and practice.)
How much more often would you say I should be routinely checking over the amp? I do my own work, I'm just seeing what anyone's thoughts are on the topic. Aside from that I take care of it very well.
If you'd like to hear the amp, it's on my bands bandcamp. Matahari. It's hands down the meanest amp I've ever played, but always bold and clean. I'd recommend them to anyone for any style of music.
I'd appreciate any thoughts or warnings.
-Rob Gee
-Rob Gee
