em field from tube amp
Hello all: Due to size constraints and overall economy of space (and convenience) I ask to you fine folks: Will the EM field of a marshall dsl amplifier interfere with rack mounted Comp (vla and older Quadraverb) if mounted close to one another? By close I mean 2.5" (inches). I need to stack the rack units atop the marshall head. I am giving 2.5" of air space between the head and the units for cooling (another issue). I have rarely combined amplifier heads and efx in the same rack unit. I did once have a Mesa 2/something 90? with a lexicon pcm and power conditioner etc in an anvil type case and it was fine.
Note the comp/efx and DSl will share the same power source but will probably not be connected directly. EFX and comp will be "outboard hardware" for other uses. I do realize potential (lol) ground loop issues) but my main concern before I start building stuff is the "buzz factor" inductance etc..?? Helps please. Thanks in advance.
