crate gx-130c
  • crate gx-130c
    not my day my gx-130c head has an issue, turns on volume is on 11(lol) and can barely hear it , chorus light is bright to dim over and over and is off ? chorus on light is bright and flickers ? clean channel is fuzzy ? any suggestions ? if its easily repairable i would rather fix it than bring it to a shop, seems it could be something small,
    First thing that I would check would be the power supply.
    You will find a +40Vdc & a -40VDC buss.
    And a +16 & -16 volt dc buss.
    The 16 volts can be checked right on an ic. Pin 4 is - & pin 8 will (most likely) be + 16Vdc.
