Howdy All,
I'm currently going thru an early 80"s Vox V125 combo, that differs from the only schematic I can find. The V125/Climax schematic from the Vox website shows a normal/bright input into 2 FETs then into the first tube stage->Sensitivity control. This one has the two inputs joined into (1) FEt stage then into the first tube. After that it goes to a "Distortion" control and then into the second tube. Any idea what this circuit was supposed to be originally? I'm curious, because someone along the way added an effects loop, around this part of the circuit and before I remove it (owner would like this amp stock), I'd like to know what might have been changed.
I'm also rewiring the power transformer to use 115v primary, it came from the UK with their funny plug and the voltage switch on the chassis only had a 220/240v option. I found a taped off lead inside coming from the transformer that seems to be the 115v lead, I'm basing that from measuring the resistance of the 3 primary leads. So I decided to wire it up to the switch so it will be 115 or 220v. Any input, pics or a schematic to this beast would be hepful. Also, if anyone has had any experience with amp and it's shortcomings, if any would be appreciated.
Matt
Matt
