The heater in one of the EL34s in my JCM2000 isn't coming on. I've measured 6.9VAC between pins 2 and 7 (measuring on the tube side of the socket), swapped out tubes, and it's the socket, not the tube. Am I missing something? What else could it be?
Marshall JCM2000, Tube Heater Not Coming On
Yes, sticking the probes in is like making a solder contact so you are hitting on a good part but the socket pin is on a cold solder joint or as Enzo said it could be broken and the meter lead just happened to hit on the good side.KB
The tube pins may not be contacting the sockets well enough. Try tightening the sockets by bending the contacts inwards with a small sharp scribe tool, or small pin. I always use the "pointy" edge of a utility razor blade. It will make sense if you look at where the tube goes in.
Good luck.
