Output transistors sockets SWR SM-400
hi
take look on the pdf catalog
http://www.keyelco.com/pdfs/prod22-trans-sockets.pdf
and online store
TO-3 Transistor Socket - Thermalloy 8113PF603
good luck
slaw
They wouldn't have been custom made. Keep searching for TO-3 transistor sockets. Fender of course now makes SWR products, they may have them, and they could probably provide the schematic you need. Is ther a brand name molded into the connector body?Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostThey wouldn't have been custom made. Keep searching for TO-3 transistor sockets. Fender of course now makes SWR products, they may have them, and they could probably provide the schematic you need.
Originally posted by Enzo View PostIs there a brand name molded into the connector body?
Mark
Oh... I bet your serial number is lower than 5105.
Now that I look into it a little, I see you must have one of the early style power amps. This WAAAAAAY predates any Fender involvement. I tend now to think they won't have them.
If it were mine, I might try to find something similar and adapt it to fit.Education is what you're left with after you have forgotten what you have learned.
Thanks for the answer. I cleaned the old sockets and asembled the amp. I still have a problem with quiescent current - I get only 2.1V between bases of the output transistors. And this is slightly too low. I'm looking for the schematic of the amp because there are may versions with different components (e.g. sometimes 180 Ohms resistor is replaced with 270 Ohms). I replaced 2SD424 output transistors with MJ15003. This should be OK, I think?
Mark
Too low? This is a quasi-complementary output, so the plus side bases are at a half a volt or so above the output, whule the negative side bases are that same amount positive from the negative rail. So I'd expect about 50v between them. Now the bases of the drivers I would expect to be about 2v apart. How did you determine you wanted more than 2v, and exactly where is it measured?
I have only seen the one version of the TO3 power amp. REvision C. Basic drawing 6/6/84, revision 2/5/91.
SWR didn't put out schematics for complete models. They had specific drawings for preamps, many of which were shared by models. They they had their basic power amp. The later power amp when they got rid of the TO3s was drawing #1011.
The 1991 drawing says it is used on all models prior to July 1992. ANy minor changes such as a resistor value are not probably done as model specific, it is more likely done to make that standard design more reliable.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostToo low? This is a quasi-complementary output, so the plus side bases are at a half a volt or so above the output, whule the negative side bases are that same amount positive from the negative rail. So I'd expect about 50v between them. Now the bases of the drivers I would expect to be about 2v apart. How did you determine you wanted more than 2v, and exactly where is it measured?
The problem is that I replaced many resistors, capacitors and I'm not sure wheather i did this correctly (in some cases it was not possible to measure the compoments - there was a fire in the amp).
Mark
The only downside to running cool would be the POSSIBLE increase in crossover distortion. If you cannot hear the crossover distortion, then the cooler the amp can run, the better. The lower that bias voltage is the cooler the amp runs.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostThe only downside to running cool would be the POSSIBLE increase in crossover distortion. If you cannot hear the crossover distortion, then the cooler the amp can run, the better. The lower that bias voltage is the cooler the amp runs.
The serial is below 3200. The amp must be quite old. It does not have a fan, which in my opinion is required with this output power.
Mark
I never use idle current through the outputs as a biasing approach.
I want the outputs set up to be just on the verge of conducting, so any signal will push them into it. But at idle, at most I want a tiny current just so they are ready to conduct. Send a sine wave through, and adjust for minimal crossover notch.Education is what you're left with after you have forgotten what you have learned.
hi
this is bias procedure for sm-400/sm-900/st-800
file upload manager does not work for me
set amp to stereo mode
insert generator to mono return jack
connect 2 ohm load to one output side
set balance controll to mid-position
adjust bias trim to full counter-clock
turn amp on
raise signal generator (from 0v) level so that 2volts rms appears at speaker output
monitor signal on scope:
load 2ohms
sweep time 50us volts/div 0.2v
signal generator freq 1khz
adjust bias trimpot just past the point the crossover notch disappears
repeat for other side
slaw
Thanks Slaw. Unfotunatelly I cannot use this pocedure because the amp still has some problems. I checked it yesterday with a dummy load and a generator and there is high crossover distortion. I can decrease it with the bias trim-pot but it is still visible. I'll keep you informed.
BTW, are you Polish (you have definitely Polish name)?
Mark
hi
yes, I am Polish amateur noob,and my experience
it is only dozen of vintage hifi tube and transistors amps which I had to
restore or repair,
unfortunately I do have sm-400, years back I had to rebuilt power supply in this amp
which is bad design from factory, this voltage dropping resistors are overheating
surrounding diodes and caps, and indeed this amp should be fan cooled,
now my sm-400 (which is the PITA to work on it) has dc offset to high on one side and
needs service again
BTW I would like to say thank you to moderator and every person in this forum for
sharing their knowledge
slaw
