Hi guys,
I would really appreciate a second pair of eyes over my thinking here. This is the Marshall 50w twin channel, reverb model as per attached diagram.
It came to me not barely working and what I have found is a few little faults that have gradually brought it back to life - but it's still lacking. This is what I have tackled so far:
0) output transformer has been replaced at an earlier time and one of the connections to the power tubes was particularly dry - cleaned up and resoldered
1) filter caps were ruptured - replaced with new FT CAP
2) A few pre amp plate resistors were a little high e.g. 120K instead of 100K (replaced with new CC 0.5W)
3) The first 10K power supply resistor had drifted high - replaced
4) Numerous dry joints.
After all that it works and sounds nice enough. But it isn't all that loud; there are two channels and both have the same problem. With both pre and master volume on full it's loud, but it only feels like 20% normal volume to me. It has a send and return loop (thoroughly checked those pesky sockets) and if I connect an input straight into the return then the output is much stronger than through the normal pre amp input, and because both channels are weak I have been concentrating my investigations around V3.
I have attached some voltage readings and the circuit diagram. It would be great if someone from the forum could point some obvious ommission in my process.
A couple of other observations is that although my meter has an input impedance of >10Mohm I noticed two strange things. 1) when I measured the voltage on either grid of the PI the volume of the audio being played at that time dipped a little and 2) All the high voltage readings appeared as one value on my meter and then settled on a lower one e.g. V1 Anode measure 290v just for a second and then 190v as though the load of the meter was just too much to bear. Can't be right can it?
Any thoughts . . . .
