Hot Rod Deville III V1 reverb noise
  • #31
    I believe you are correct g-one in that the noise was still there, just faintly. I also see the point made by Jazz P Bass regarding the pre amp out but I definitely had the noise feeding into another amp. ? In any event, I replaced the ribbon cable to eliminate it as a potential problem and the amp has been noise free for several hours now.
    • #32
      Originally posted by g-one View Post
      Did you download from the link in post #7? If so, and you still can't see the schematic, then the problem is with your computer.
      We have all downloaded it and can clearly see the schematic on page 1 and 2 of the schematic.
      Stop pretending the problem is with the file or the Fender site. No one else is having a problem with the file.
      I never said there was any problem with the file or the Fender Site.
      You made that up. (as usual)
      I said that I am looking at a blank page, and I am not pretending. (you made that up also, as usual)
      No one else is having a problem? There IS one problem: I think your imagination is having a problem.
      You love to make up stories about what I say. That is a problem. You must be republican. (how DID I guess?)
      • #33
        Still don't see any schematic. Just a blank page. Everything else is there however...
        Same on the Fender website.
        From your post #27.
        To any thinking person, that reads like you open the files and see no schematic. If you are playing little semantic games about putting blank areas on your screen, then enjoy yourself. As much as I find you distasteful, I am not going to bother making up a story.
        Everyone else has opened the file and found the schematic.
        • #34
          Well by golly that must be it!!
          • #35
            Soundguruman, check your computer. The PCB could have carbonised and made the document look empty.
            • #36
              The letters are pushed down on the screen & there is a carbon track between them.
              Or maybe his computer monitor was made by Crate.
              • #37
                Yeah, it was a shitty import monitor wired for 100V line voltage.
                • #38
                  There's no complete schematic for the amp, reverb, etc...not even on Fender website.
                  (not posted here either)
                  Do you even look at what you're talking about?
                  There IS no schematic post #7. It's the power supply and board layout, NO schematic.
                  Obviously you don't even know what you said, but do you even know what you think?
