OK I am going to visit the tremolo issue later because I want to deal with bias issues first
I measured cathode current and am getting 38ma on the EL84 which is way to much. Plate voltage is 400. This is pretty common with these amps I have read. I want to add a bias bot to adjust bias to proper levels.
R39 is the bias resistor (22k). I have a 10k trim pot to use for bias. I want to make sure I do this correct so thanks for the help: Do I remove replace R39 with a smaller value? if so, what value? Then I need to add the 10k trimmer in series to the new R39 and then ground the trimmer right?
Could someone walk me through it (or a simple diagram would be even better) I know 1/2/3 pots lugs so explaining the wiring would probably be fine.
