Received this and none of the tubes would light up....Power would come on and stay in protect mode....I opened it up and somebody had gone in and removed the wires from the stand-by switch and connected them to the un-used section of the main power switch...tore it all apart and checked all the traces to the heater pins on the output sockets...also measured heater voltage from the two white heater wires......plugged the tubes in a tube tester to verify that they at least light up....everything was fine....Re-connected the standby wiring back to the standby switch...and this switch also good...on both sections...the tubes all light up now....when turned to run mode, there is a hum in the speaker which signafies the tubes are not balanced....adjusting the bias pots don't do much...the relay is cycling every few seconds...I am going to rip it apart again and do some more component testing to see what I can find....any comments kindly welcome......
Cheers
Bernie
P.S. Found a ribbon cable that was not fully seated......the one that goes to the main board......Now I hsave it powering up and have a mis-match is a tube or two...so the process of elimination begins......
Cheers
Bernie
