I've got a Fender Ultimate Chorus here, arrived with a blown mains fuse (FX1), and two shorted power transistors (Q8, Q9, shorted collector to emitter on both).
Combed through the power amp components. Can't find anything else bad in there.
Replaced Q8 and Q9 with same type transistors (TIP142/TIP147).
Power up with dim bulb, and no load. Seems OK.
Take off dim bulb, power voltages match the attached schematic just fine.
Monitor idle current by measuring voltage across emitter resistors R112, R113, and it's shooting up fast - turn off amp. (Still no load, no signal.)
R131, R132, emitter resistors for the OK other power amp stay put at around 56mV. R112, R113 shoot past 1V quickly.
The power transistors bases are all at about 1.2V to ground, positive for the NPNs, and negative for the PNPs. Collectors are at +/-41V, and emitters start at about 100mV and steadily rise. Transistors quickly get hot, so I don't keep the amp on for even 1/2 a minute.
Checking U8/U9, the MC1436 op amp drivers, the good amp (U9) output pin 6 locks in at about 23mV, and the bad amp (U8) output pin 6 steadily creeps up about a mV a second.
Still can't find a bad part, so I swap U8 with a new MC1436, no improvement. (U8/U9 power supply pins are both at +/-26V.)
Both U8 and 89 have similar input pin voltages. Here's all the voltages:
pin 1 - nc
pin 2 - ~2-3mV
pin 3 - ~100µV
pin 4 - -26V
pin 5 - nc
pin 6 (good amp) = 23mV
pin 6 (bad amp) = starts around 23mV, steadily rises about 1mV/sec in sync with the increasing current in the power transistors.
I've tried checking in-circuit resistances just about everywhere and I can't find any clues, and every measurement squares with the working amp. So I've now taken to removing components for out-of-circuit testing, but still can't find a bad component.
The biasing diodes all check OK (CR30-CR33) and there is a total drop of 1.48V when I measure Q8 base to Q9 base, forward bias, and open circuit with reverse bias (this is with the diode checker on the meter, amp powered off). This matches the other side. Voltage at the top of R109 is 13V, and the bottom of R110 is -13V, and matches with the other amp.
Something is turning these transistors (Q8/Q9) on and I can't figure it out. I really want to blame the op amp circuit, maybe something wrong with the dc feedback paths. R102, R101, R100, and C58 have been checked, as well as R98 and C56, and the resistances between pins 2&6 and those pins to ground match perfectly between the two power amps. And, as mentioned earlier, I've already replaced the op amp.
Any ideas on where to look next?
pin 1 - nc
pin 2 - ~2-3mV
pin 3 - ~100µV
pin 4 - -26V
pin 5 - nc
