Hello gang.
I have a mesa subway rocket (non reverb) that has very low volume. Its a ~20 amp that sounds like a 1 watt amp. Everything functions as it should, just very low volume, both channels, fully cranked.
Schematic attached
I have swapped all preamp and power tubes with no change in volume.
I plugged in a boost pedal into the effects return and the volume was decently louder with the preamp bypassed so I suspected preamp issue but still not sure.
Signal traced through the preamp and power tubes and can't detect any noticeable volume drop anywhere with my tiny speaker and probe.
Plate voltage is 370 and bias is 40 m/a so its running pretty hot but I believe mesa designed it that way and that shouldn't make the volume low either.
I appreciate any advice on this. Thanks
Schematic attached
