Hi,
I got my hands on this amp :
http://i1299.photobucket.com/albums/...ps0fbc0371.jpg
http://i1299.photobucket.com/albums/...psf367a220.jpg
http://i1299.photobucket.com/albums/...ps51775cea.jpg
http://i1299.photobucket.com/albums/...ps12b7da43.jpg
http://i1299.photobucket.com/albums/...ps27d620c8.jpg
http://i1299.photobucket.com/albums/...psf6bc5abb.jpg
http://i1299.photobucket.com/albums/...ps7adb9c96.jpg
I couldn't find the schematic for this one. It seems to be a pretty rare amp.
The tubes are : 4x EL84 output tubes (the ines put in a square position) and the rest is all 12AX7.
The standby switch isn't actually a real one as it grounds the input of the phase inverter instead of cutting B+)
The amp seems to have been made in the beginning of the 70, as it is mostly tubed but has some transistors too. The reverb drive/receive circuit is transistorised, the rest is all tubes.
As you can see of the pics, I recapped it completely.
It works perfectly, excepted there's a slight but annoying hum (50 Hz) on the output. Most of the hum seems to come from the phase inverter, as it's still present when the input tubes are removed and disappears when th PI tube is removed. It is still present with the vibrato oscillator tube removed. I swapped the PI tube with some new 12AX7, problem still remains.
I first suspected the heaters, as those aren't fed with twisted wires but directly wired on the PCB. I cut those traces on the PCB to keep the AC far away from the PI circuit, and fed the heaters with an external +/- 6,3V DC supply, but the hum is still present, unchanged.
There is a ground loop on the main circuit, as the PCB is surrounded by an uncut ground trace. I cut the trace to try removing the loop, but the hum got only stronger
I must admit that I don't know what to try now...
If anyone here has the schematic for this amp, I would be really happy to get it !
Any idea to go on the toubleshooting would also be really appreciated.
Thanx in advance !
Best regards.
Eric
Thanx in advance !
Best regards.
Eric
