Originally posted by Jazz P Bass
View Post
Lost the distortion on an Orange Crush 15R.
To me what you describe sounds like an intermittent problem since the clipping kicked on for moment. Try chop sticking the components and tapping on the board to see if you can trigger the possible intermittent problem.However, it still could be something else but first I would rule out bad solder joints all throughout the clippings stage of the circuit. A signal tracer might prove to be valuable in a situation like this one.When the going gets weird... The weird turn pro!
Originally posted by bclemons View PostI just powered it on to test the effect of the gain pot again and the clipping came on for just a minute, and then was gone again. The regular gain pot seems to be working fine and the overdrive level pot (when the switch is engaged) provides a significant volume boost when turned up, regardless of the regular gain pot position. Maybe the diodes aren't getting to ground properly? The soldering looks good on the diodes.
Here's how I think it works - someone please correct me:
The pot is in parallel with R112, and the pot is wired such that when CCW its value is 100K, and when CW it is 0.
So when the Overdrive pot is CCW, R112 is in parallel with 100k.
As the pot is turned up, the value of the pot decreases, so the value of R112//Pot decreases, which increases the gain of IC101.
Additionally, as the gain pot is turned CW and approaches 0 Ohms, the switch end of the diodes gets closer to ground. As this happens the signal voltage than can be developed across the series combination of the diodes + the pot decreases as the diodes start to clamp the signal.
Originally posted by TimmyP1955 View PostHere's how I think it works - someone please correct me:
Looking at it that way, I'd expect when the amp goes from fizzy to non-fizzy there'd either be A) a loss of perceived volume because the pot or the switch went open and the 'boost' function shut off, or B) a jump in perceived volume because the diode network went open and there's still a gain increase but no actual clipping.
@bclemons: when the clipping came and went, was there a clear change in volume? Which way?If it still won't get loud enough, it's probably broken. - Steve Conner
Turn the overdrive control all the way up to 10, as this is where the diodes are fully engaged and the stage gain is highest. Now use the gain control to set the amount of distortion and the master volume to set the overall level. Doing this, can you get a good distortion sound?
Originally posted by 52 Bill View PostYou may be looking at this in the wrong way, it isn't a channel switching amp with a clean and dirty setting. It is a single channel amp that can be set up to distort.
I wouldn't say it's entirely your fault. That has to be the most confusing labeling of gain structure I've seen on an amp. They couldn't have f'd it up more if they tried."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by The Dude View PostI wouldn't say it's entirely your fault. That has to be the most confusing labeling of gain structure I've seen on an amp. They couldn't have f'd it up more if they tried.If it still won't get loud enough, it's probably broken. - Steve Conner
Additionally, as the gain pot is turned CW and approaches 0 Ohms, the switch end of the diodes gets closer to ground. As this happens the signal voltage than can be developed across the series combination of the diodes + the pot decreases as the diodes start to clamp the signal.Last edited by bclemons; 03-20-2015, 03:09 AM.
Originally posted by bclemons View PostSo, if I put some diodes with a higher forward voltage (like LED's) in place of the IN4148's, the increased negative feedback produced will prevent a volume jump, like I would get from the same modification to a clipping circuit that connected the diodes to ground?If it still won't get loud enough, it's probably broken. - Steve Conner
