Hello,
I have Divided by 13 amp (13/29 model) that is instantly popping mains fuse when main power switch turned on (standby in off position). Unfortunately they wont provide a schematic so that is a limitation.
It is not a tube issue, have all tubes removed (GZ34 rectifier, KT66 power, preamp tubes) and still blows instantly. Hooked up to my current limiter bulb and it is glowing bright with no tubes in.
No visible filter cap distress that I can see, dropping resistors ok as well.
I am checking resistance on the PT primary leads and getting about 4-ohms. When I check each primary lead resistance to ground I get nothing on the meter. PT toast? I don't want to assume that but I think I should be seeing high resistance from primary to ground right? Any ideas on what to try next?
Only a pic sorry:
Only a pic sorry:
