Hi everyone, nice forum you have here. I am an amateur electronics hobbyist who is having problems with a Marshall VS100R that is about 16-17 years old. The amp is working "ok" (everything functions normally). But my main issue with the amp is that is making a Hiss/ white noise on only the clean channel, with volume at 0. There is also a low electrical buzz on all channels. The white noise is sort you would expect if the amp was turned up to high volumes.
Here is an example of how these sounds occur:
With the amp off and all volumes at 0 (Clean channel and OD channels):
1. I plug in my guitar, I turn the amp on (clean channel), immediately there is a low electrical buzzing sound from the speaker (I can also hear this from the transformer area when the chassis is out of the amp cabinet)
2. About 4 seconds after turning on I can hear a "pop" then a lowish but easily audible white noise/hiss sound comes in and builds in volume.
3. If I now press the OD switch (again all volumes @ 0) the hiss disappears and I can just hear the low buzz. Go back to the clean channel and the hiss is back.
4. If I pull the guitar plug out, I can still hear the buzzing from the speaker. The white noise is gone though.
Other observations:
If I plug the guitar into the Effects Return there is no white noise on the clean channel (still buzzing though).
If I use the Headphone jack, I can't hear the Clean Channel white noise (or buzz).
Things I have done so far in an attempt to (unsuccessfully) resolve the problems:
Used contact cleaner on all the jacks/pots/switches.
Fixed multiple cracked solder joints
Replaced the pre amp valve
Replaced/ socketed IC4
I don't know how long the amp has been like this or how much of this stuff is "normal". I could just continue to use the amp and ignore the sounds, if I was playing loudly with a band or just
jamming about...but I am trying to record the Clean Channel and this is what caused me to notice these odd sounds (with the amp at 0 volume, this is a really undesirable noise floor to start with before I even add any other noise from amp volume/guitar etc). The fact that only the clean channel makes this white noise and not the OD channels (especially with the volume off) really causes me to believe something is not right and can be fixed.
Here is the schematic for the VS100R: http://www.amparchives.com/Amp%20Arc...s100r_100w.pdf
Thanks for any guidance or advice.
Other observations:
