I have what I believe to be one of the earliest JMP 50 watt heads. Owner tells me it is a model 1987 (not year) built in 1967. It has a GZ34 tube rectifier and has the output selector with 100v marking painted over. The 8 and 16 ohm taps measure 0.7 and 0.9 ohms to ground respectively, and the painted over tap measures 0.5 ohms, so I think we can assume it is a 4 ohm tap.
I cannot find a proper schematic for this amp anywhere. All I can find is the solid state rectifier version issued in 1970. I am replacing the 5 electrolytics on the board, but 3 of the five do not match this drawing. The cathode bypass cap on V2 shows 320 uF, but has a 250 uF in it. And the two 50 uF on the plates of V1 and V2 are 22 uF 450v in it now. If no one knows of a schematic for this version, can someone at least confirm that the values in the drawing are the correct ones?
And also, whats up with the 50 uF filter cap on the outputs with the positive side grounded? it's not that way in the amp. I also have a discolored 1 watt resistor after the choke that reads 8.3K ohms that I would like to confirm that also.
It also has a .05uF 1000v cap across B+ and ground. What is the opinion on that? Seems like if it got leaky bad things would happen. Should I treat like a death cap and clip it?
http://schematicheaven.net/marshalla...d_50w_1987.pdf
