I just finished wiring in an isolation transformer. The original schematic is below and a 2nd one with the changes to the circuit. As you can see this amp had a floating ground. I changed all the grounds to the chassis. There is a slight hum with the volume down, but certainly not loud enough to be a concern.
The hum that it has is affected by the volume, is there something that could be change to make it quieter?
