Fender tweed bassman 5F6 no sound
  • Fender tweed bassman 5F6 no sound
    This amp is not passing signal. It has signal up to the grid of the phase inverter, pin 2. The voltages on the phase inverter seem really high. They are:
    pin 1 430vdc
    pin 2 330v
    pin 3 385v
    pin 6 430v
    pin 7 starts at 300v and goes down to 200v
    pin 8 385v
    I've don't quite a lot of work to find out why the phase inverter has these voltages: changed socket, lifted board to observe whats going on underneath, lifted/suspended all the components 1M , 470R, 1M and 10K resistors off the board keeping them in circuit and still have high voltages.
    Am I reading these voltages wrong?
    does anyone have any ideas what's happening here.
    Thanks in advance.
    pete
    PI is grounded via the presence pot,check out all ground connections first.
    you could have a wrong wiring,if its really 330V on grids you can toss the tube,take it out and measure what you have pin by pin.
    is this a kit you built?
    post pics of the amp
      Those cathode voltages are incredibly high, measure resistance from each cathode to ground.
      You might have lost connection from preamp ground to chassis ground (the metallic chassis itself) and real power supply ground (negative of filter caps).
      Place multimeter black probe at first cap ground at the PSU and remeasure voltages, also what voltage you have available across the first filter cap, also what voltage appears at chassis and preamp grounds.
      No, do not assume it´s a waste of time because "everybody knows it should be 0V" , just measure and report.
      Also am amazed at the very high plate voltages, pins 1 and 6, what is rail voltage at the other end of corresponding plate resistors?
      Of course, also check multimeter, use another one and compare results, it might be out of whack or have a dead battery.
        Thanks for responding so quickly.
        I started with hooking the feedback resistor in place. It had been taken out by another tech when I got it and that was it to getting sound.
        Pin 1 280v
        pin 2 69v
        pin 3 110
        pin 6 280
        pin 7 70
        These voltages are looking a lot better, still a bit high compared to the schematic but it's passing a pretty signal.
        Thanks again.
          Most clones and all vintage amps of that model will have higher voltages than the originals because most clones aren't corrected for modern, higher mains voltage and, of course, none of the originals were either. Just make sure the bias is appropriate for the existing voltage.
            Thanks Chuck, bias is good at about 27mA. This is an original 1960 bassman 5F6. It needs a cap job, that will probably change the bias a bit, but we'll find out after that happens.
              You mean the 27K feedback resistor? If hooking that back up fixed the voltages and gave sound, something is wired up wrong.
              Or maybe it was just coincidence and there is a bad connection or presence pot fault like alexradium suggested.
              Disconnect that resistor again and recheck. If you lose sound and the PI voltages go funny, something is miswired.
                absolutely,the amp performs equally with or without feedback,as far as biasing of preamp and power tubes,the only influence it can have is to eventually give positive feedback in presence of signal,but idle it shouldn't matter at all.
                  The amp came to me with the transformer wire for the output dangling and I was clipping the black wire to the chassis and to a load when working on it. But wiring in the 27K resistor brought the sound back. Just tried it again, lifted the 27k feed back resistor and no sound and very high voltages on PI
                    That's wrong. Shouldn't happen like that. Check the layout against your work (it's available on line). If you still don't see anything perhaps you could post a photo of the work.
                      Here's a picture. I went through the layout/schematic many many times and there aren't a heck of a lot of connections in a 5f6. When I've built these before I clearly remember connecting it up without the feedback resistor so I agree something's up. I hope someone can see what's wrong.
                      edit: here's another picture after I touched up horrible solder joints
                        Maybe the presence pot is bad? It looks like it may not be wired up correctly either.
                          being an original,i'd take in consideration also leaking caps and conductive board,pretty strange anyway.
                            So lift the 27k NFB resistor, and measure resistance to ground from the point it was connected to.
                              Enzo, not knowing which ended I should lift of the 27K I lifted both. The one that is closest to the speaker jack has .3 ohms to ground the other is open.
                              Across the output transformer from black to green it measures .3 ohms.
