Silverface champ with blown factory speaker. Replaced with weber 30watt ceramic. Sounded harsh, played around a few hours, 6v6 went bad. Lighting up shorting out at higher volume. Replaced tube. Checked the bias/output of the tube. Calculated output at 22watts! I could see where the speaker and tube would go bad. Increased cathode resistor until output was about 10 watts. Output was harsh, clipping was muddy and distorted. Adjusted down to 8 watts, better, but still bad.
Could this be an output transformer problem? I heard these tiny little things were weak, could it handle 22watts? It sounds marginal up until about 5, then really goes south. Any tips on troubleshooting?
Thanks
Doug
Thanks
Doug
