When plugged into a light bulb limiter, the light flashes on and off fast.
When the power supply is disconnected, the light doesn't light.
I hooked it back up each connector separately, CN203 on the amp board makes the light flash (also a sound pulses with the light and no source)
I tested the outputs and found one I believed was bad. (cricket test with an old sencore). Not sure how to test these and/or if the sencore works for these.
I replaced both, the one I thought was bad didn't do anything, the other made it flash dim instead of bright.
The guy said it got rained on while on.
I've never had the light pulse, not sure what to do next.??
