Hi all. Recently, I've been having a problem with my Ampeg SVT CL head; intermittantly, I have been getting a very bad static sound with the signal cutting in and out. It goes away at times, and sometimes is only present when really digging in and on the lowest notes. I've bypassed the preamp section and used the power amp with another preamp with no problems. Also replaced the preamp tubes and the problem still exists. I've switched basses, speaker cables, cabs, and inst. cables as well and it's still there off and on.
I'm thinking the input jack/ground is going bad as it comes and goes when I wiggle the cable in the jack. It all started when I was doing general maintenance with some Caig DeOxit in the jacks - go figure. I'm here in AZ so static is a real problem. The low input jack does it as well, but not to the same extent.
Any other suggestions/similar experiences before I replace the jack?
Cheers,
JR
Cheers,
JR
