Troubleshooting a "Refreshed" Fender SF Pro Reverb
    Ok. The question now is *Why not?*
    Because it should. According to the schematic it should be tied to pin 3 of that same socket and then to a 25uf cap parallel with an 820r resistor on the board that are to ground.
    With that pin not connected the tube will not conduct. This could explain the low volume and lack of reverb.
    I see exactly what you're saying when looking at the schematic about pin 8. I've taken some pictures of the chassis today so you can get a better look at the wiring for V4.Click image for larger version
ID:	856068Click image for larger version
ID:	856069Click image for larger version
ID:	856070Click image for larger version
ID:	856071Click image for larger version
      Ok!!! Well, somebody's been in there eh?
      The orientation of the reverb transformer looks to be 90° different from what I'm use to in earlier amps. That threw me off for a second. I think those cathode circuits going to the RCA jack frames for ground isn't stock, but I've not been inside one of these amps before. Still, the component values for the V4 cathode circuit look right so try connecting pin 8 to pin 3.
        Thanks for your input Chuck. So (just to review) I need to connect pin 8 to pin 3 using a jumper wire, correct?
          Correct.
          No guarantees how it will work out though. I can't know what sort of changes may have been made to the amp. No risk of damage to anything.
            Am I seeing things or is pin1 connected to a heater wire? (pin8 is without connection)
              It looks like that in one of the shots. Furthermore, it's hard to tell otherwise in all but one of the other shots. But I don't think so.
                see edit, post #20
                  [ATTACH=CONFIG]55989[/ATTACH]
                  Yes, that's how it is currently connected, or not, in the case of pin 8. Pin 8 appears to have some traces of solder on it. The amp, to my novice eyes didn't seem to been modified in the past. Having said that, it certainly doesn't seem to be wired correctly..... I attempted to get as much detail in the photos as I could.
                    " I think those cathode circuits going to the RCA jack frames for ground isn't stock, but I've not been inside one of these amps before."
                    Actually, this is indeed stock. I have one in my shop right now that is this way.
                      I see what you mean now Chuck. That heater wire isn't going to pin1, but tucking around under and going to pin 4/5.
                        Originally posted by pdf64 View Post
                        Just noticed the above, 'coupling caps' seems odd, was that just a terminology error, or have ecaps been used for coupling purposes?
                        Confused by this, the neon couldn't flash if it's been removed from circuit?
                        My take on the thread is that
                        1/ the amp seems to have been modded as the master doesn't seem to affect the normal channel (true?); so need to verify the circuit to its intended schematic.
                        2/ from the bent front panel, the master volume may have received a massive bash, may be broken, and given the symptoms must be replaced, or just taken out of circuit. Hardwire the pull boost switch in the non boost mode.
                        3/ a voltage survey and idle plate / cathode current measurements (eg resistance and volt drop from OT CT to each plate) would be very useful.
                        I just reread all of the comments and postings, thanks to one and all. I would like to narrow the field of possibilities, a process of elimination to get to a solution. I seem to have a partially functioning amp with the power section working and part of the preamp working. The reverb and vibrato channel are malfunctioning. Based on the schematic I think I need to troubleshoot the signal path and confirm the function of the master volume.
                        I do have a signal generator and scope to help out. Voltage and current survey as pdf64 suggested might also be enlightening. Any pointers or starting points would be greatly appreciated.
                        • #27
                          Did you tie pin 3 & 8 of V4 and now are still having the problem?
                          (sorry about the heater wiring distraction)
                          • #28
                            THIS^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
                            • #29
                              I went and tied pin 8 to pin 3 and sure enough I'm now getting full output from the vibrato channel. I believe that in process of changing out the capacitor tied to pin 3 I seem to have forgotten to connect the capacitor lead across to pin 8. All of the tone controls and the MV are all functioning with both channels. I haven't had time to reconnect the reverb tank (getting late), but the I'm pretty sure it's going to work.
                              Thanks so much to all the contributors in this thread. I may be back with a few more questions related to this amp
