MEF Members -
I am working on my Peavey Solo Series Special 112. For good measure (and because I have boxes of caps), I replaced the High and Low Voltage Supply caps. There is negligible ripple on the caps. I am measuring +43.3 vdc on the positive rail and -43.3 on the negative rail.
I am using an 800 hz signal into the clean channel. With an 8 ohm load, I see approx 22.5 vrms (~83 watts) before the signal oscillates. And with a bit more signal, it will then flat line (clip) on the upper and lower ends of the wave - but the oscillation is gone. The signal seems to be back to normal looking (with the exception of the clipping).
If I try to repeat the test using a 4 ohm load, I can only get to 10 vrms before the amp goes into oscillation city.
With this test alone, is it possible that the output devices are breaking down because of heat? The original 70483100 (NPN) and 70473100 (PNP) remain in the amp.
Any hints on where to look and other tests I should run?
Thanks, Tom
Thanks, Tom
