I have a couple other threads on this amp, but I figure why not keep overthinking it, right? Amp is an Eden E300T 300W tube amp (same as WTB300V). Original OT was bad, I am trying to put in an SVT CL transformer into it. Looking at the schematics, the Eden amp took the FB point off the 8 ohm tap. The SVT transformer doesn't have an 8 ohm tap, only 4 and 2. It seems like this would affect the feedback ratio, essentially reducing the feedback by a factor of 2. I think it reduces it because a 4 ohm tap will be lower voltage and higher current than an 8 ohm (right?) and the feedback is voltage based, not current, but I am not sure, and therefore I ask.
Looking at the schematics it looks like the feedback comes back to the same point in the circuit (the cathode of the first PI stage), but they do have a different voltage divider ratio there. Eden also uses a 12AT7 instead of a 12AX7 like the SVT, but not sure if that would also affect it.
WTB_300V.zip
93_SVT_CL.zip
Thanks in advance,
Greg
WTB_300V.zip
93_SVT_CL.zip
Thanks in advance,
Greg
