Originally posted by nickb
View Post
Before the transformer ultimately ended up failing, I remember having this thing on my bench a while back for a good amount of service (I swear, when it left if was in great shape )
That was the first time I'd seen one of these big old Matamps on my bench so I remember the job pretty well. I remember measuring secondary DC voltages, and can confirm very similar readings to the ones Catalin posted in his example. The amp would show an unloaded high voltage in the low 700s. But it would fall rapidly to around 640V or so as the tubes began to conduct and ultimately settle under 600V to around 580V or so (if I remember correctly).
So, when it came back in and the PT needed to be replaced. I had to remove the PT anyway, so I pulled all wiring from the turret board and cleaned it up as well to make sure I didn't misread the print on the board. I knew and recorded where all the connections were made, so I was surprise to see those kinds of secondary voltages labeled. I was projecting secondary voltages according to that rectifier into a common capacitor input, and it wasn't jiving with what I remembered measuring before. But now we can all relax, because it's all starting to make sense.
Have you tried talking to Orange?
