Originally posted by g1
View Post
Bugera T50 - Intermitent (mostly no) Sound at the Speaker Out, but signal at the FX Send
Originally posted by Enzo View PostFluke is a quality brand for sure, but there are many brands of good meters.
Originally posted by stoneattic View Post
It seems like most reviews, particularly from that site I posted the link to, is from an electrician or home owner doing house wiring standpoint, Even the most of the manufacture's buying guides don't address electronics specifically. What features would make a DMM more for electronics (in my case specifically music/guitar gear like tube amps, SS amp and pedals)?
I wouldn't buy a meter without knowing about meter input impedance with DCV and ACV.- Own Opinions Only -
See my post #67. Electricians probably don't need the most important first three features of my list. They hardly have to measure AC on DC, DC mVs, frequencies above 400Hz and many meters have too low input resistance/impedance to correctly measure plate voltages or voltage drop across large resistors.
Maybe I'm just missing it, but I have not seen specs or features listed on a meter that explicitly says it will read AC on DC. Would it be described in another way?
I always thought this would be normal until I found out that many of the cheaper meters don't have this essential feature.
I'm not even sure if the more expensice Fluke 115 is AC coupled (deleted it from my post above).
Without AC coupling you will need the additional cap for measuring AC on DC.Last edited by Helmholtz; 07-19-2020, 07:52 PM.- Own Opinions Only -
It should state "AC coupled" for ACV ranges. The ACV symbol should look like this ~ without any additional lines (indication DC coupling).
I aleays thought this would be normal until I found out that many of the cheaper meters don't have this essential feature.
So does that mean it is AC coupled?
Ugh, I still have not been able to figure out which multimeter to get.
The 115 there says 'true RMS' right on it. I don't think you will find a true RMS meter that is not AC coupled on the AC range.
I think all but the cheapest meters will have proper AC coupling when on AC range.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostThe 115 there says 'true RMS' right on it. I don't think you will find a true RMS meter that is not AC coupled on the AC range..
I read the 115 manual and it wasn't clear about that point. I tend to think that the normal ACV range is AC coupled, while the AC mV range might be DC coupled.
Edit: Read the 115 manual again and found the all important note:
"AC volts is ac-coupled. Auto-V LoZ, AC mV, and AC amps are dc-coupled. "
https://dam-assets.fluke.com/s3fs-pu...bVGUu8WPBGUjJu
So the 115 would be fine.Last edited by Helmholtz; 07-19-2020, 09:26 PM.- Own Opinions Only -
