Originally posted by Leo_Gnardo
View Post
Mesa 2:90 woes _ tubes not coming on
- Likes 1
Originally posted by Yovan View Post
I fixed it finally! Thanks for your help - if you ever find yourself in Scotland Central belt then your beers for free.
- Likes 1
Leave a comment:
Originally posted by Leo_Gnardo View Post
Measure the AC voltage at your output tubes' filament. Maybe you ran one jumper to ground, the other to 6.3 VAC. That would result in 3.15 VAC, dim filaments, very low power.
The ring mod effect, I dunno. OK I s'pose, if you want to get those early jazz-rock-confusion tones from 45-50 years ago, Larry Coryell, John McLaughlin, Jeff Beck. Nah... I didn't think so.
- Likes 2
Leave a comment:
So...
I managed to wire it all up again with the wires on the correct points. The amp powered up and the filaments bright again, played through but couldn't hear any signal at all out either side...
also after I switched the amp off - the step down transformer died - neither fuses from either the transformer or the plug blew so it's odd. Any ideas what the cause might have been?
I'm going to take a break now from the soldering and look at it again tomorrow probably
*edit*
sloppy fault checking on my part - it was the plug fuse in the transformer, I checked the wrong plug (whoops)
so hopefully the transformer is okLast edited by Yovan; 07-19-2020, 03:49 PM.
- Likes 1
Leave a comment:
Tinkering continues....
kept digging to figure out what I did wrong - it seems that the green filament wires have a third earth wire which is melted (completely melted to one of the filament wires) somewhere down the line also one of the filament wires that was in the multipin had blackened so I assumed it was black (first mistake) and connected it to the black wire in the board. I'm not sure if my actions caused the meltage however I've disconnected the wires and the power transformer and removed it so I can sort out the problem.
I'm fairly sure there's some damage to the circuit but it's hard to say what the extent is, the filament pin which was burned was completely pulverised when I disconnected the wire, there was a track running under it but because I can't see under the board I'm not exactly sure where it goes or what it was connected to.
Perseverance
Leave a comment:
Kept tinkering for luck - think I bridged the wrong connection and was causing a short so I snipped one of the wires and now the amp powers up on one side, more power than before but still weaker than it was when it worked.
Leave a comment:
Actually I think I might have knackered the amp - one of the tracks pulled off when I was soldering so I bypassed it with a wire and now when I power on the amp, smoke starts pouring out. Looks like a fire hazard now and I've probably reached my limitations. Hope the amp is still repairable but not sure if it's within my capabilities to be honest
Kept tinkering for luck - think I bridged the wrong connection and was causing a short so I snipped one of the wires and now the amp powers up on one side, more power than before but still weaker than it was when it worked.Last edited by Yovan; 07-17-2020, 09:45 PM.
Leave a comment:
Originally posted by Yovan View PostOk I've done work on the amp, after powering up the filaments came on but only very slightly and although there is sound to the amp it's faint and sounds like it's going through a ring modulater.
Leave a comment:
Leave a comment:
Bingo! At glance it seems at least one of the pins is singed to a crisp. So I should bypass the burnt wire and leave the others?
- Likes 1
Leave a comment:
Ensure you make good the two high current heater connections.
Why they use cheap and nasty connectors, I will never understand except it gives built in obsolescence.
- Likes 1
Leave a comment:
Originally posted by Leo_Gnardo View PostIf your 2:90 has a comb type multipin connector on the power supply board, with a gaggle of flying leads to the tube boards, it's possible the filament pins on that connector have oxidized due to being heated from all the current they have to carry. It's a common problem on a lot of their combos & heads after they went to this type of connector. If you find that to be the case, I don't think there's much point in cleaning up the pins on the board, and sometimes the electrodes in the multipin connector are burnt beyond repair anyway. In these cases, I run a pair of heavy gauge wires directly between the boards, scraping enough of the board coating off the lands so I can get a reliable connection. Luckily the filament pins are the only ones I've found to have this kind of problem - the remainder can safely be left in place.
- Likes 1
Leave a comment:
- Likes 3
Leave a comment:
- Likes 5
Leave a comment:
I don't see any internal fuses on the schematic (see attached), but I don't trust Mesa schematics either.Attached Files
- Likes 1
Leave a comment:
Leave a comment:
