View Post
Laney TT50H No Outout
Now I realize that the socket mounts on this side of the board so the wire would prevent it from mounting flush. So the wire would have to run around the outside of the socket, rather than under it.
Leave a comment:
The part you quoted in post #107 I was talking about your epoxy patch at R43.
Originally posted by ca7922303 View Post
Should have said now exposed trace next to hole is showing connection to all preamp tubes V1-V6 pins 4 & 5.
Originally posted by ca7922303 View PostThe exposed trace next to hole is still connected to pin#4. Do I still need to run a jumper wire? If so, is it to connect pin#1 to exposed trace?
If you scrape away the whole exposed portion near the hole, and run an insulated wire across the hole, it is highly unlikely that it would arc again. 18 gauge wire should be sufficient.
It would look something like this:
Leave a comment:
I think it is probably ok if it's not close to any other traces except it's own. Neither side is near ground potential like that heater trace is. There is not a big voltage difference between the 2 ends of R43 so it's not likely to arc over. If anything the carbon under it will be in parallel with R43 which would effectively reduce it's resistance value.
In any case it should not have anything to do with the hum balance pot issue.
Leave a comment:
In any case it should not have anything to do with the hum balance pot issue.2 Photos
Leave a comment:
Any way of knowing if what I've done under R43 is good or could it be part of the issue still with the hum balance?
Leave a comment:
Originally posted by g1 View PostThe carbon must be removed. It is like a resistor and offers a path for the arc to strike. Epoxy won't do anything about that resistive path.
If you mean, can you use epoxy instead of corona dope once the carbon is removed? Yes it should work.
But having corona dope will be handy as you will likely have to deal with arcing again if you are working on tube amps.
Leave a comment:
Leave a comment:
Originally posted by g1 View PostYes the black carbon will need to be ground/cut/drilled out. Be careful not to cut into the traces on the other side of the board. Then some corona dope or brush on high voltage insulation over the repaired area and the damaged trace. Or grind out the damaged trace as well and run an insulated jumper wire across the break like The Dude mentioned.
Leave a comment:
Leave a comment:
You'll have to grind out that burnt (blackened) part of the circuit board. Burnt circuit board can be conductive. It also looks like the trace may be burnt open (check continuity with meter). You may have to add a jumper wire.
- Likes 1
Leave a comment:
Originally posted by g1 View PostThat's pretty bad. The trace that has the green scraped away goes to pins 4 & 5 I guess. The arc from pin1 to that trace is what is putting the high voltage DC on the heater circuit and hum pot. The burnt area between pin1 and that exposed part of that trace will have to be drilled or cut out. The trace will have to be insulated again with nail polish or something. Or cut back and replaced with wire. The socket should clean up as the arc was not between pins.
Clean the board and socket up as well as you can and post pics.1 Photo
Leave a comment:
Leave a comment:
Leave a comment:
