This amp was brought to me blowing fuses. It turned out to be a bad power tube. But another problem has surfaced, again with the standby/voltage regulation circuit (I have a YCV40 thread on here from a couple of years ago for a low B+ issue https://music-electronics-forum.com/...or-ycv40-low-b). This time the amp is operational even with the standby switch engaged. I still don't understand how that voltage regulation circuit works, but obviously U3 somehow shuts down the high voltage. The 24V supply from Q1 is working and R55 measures 4.6K (tested in circuit with the standby switch engaged). Pin 1 of U3 is grounded with the switch engaged (down) and has 1.1V on it with the switch released (up). According to the datasheets for the 4N35 the "Typ" forward voltage is 1.2 or 1.3V (depending on whether I'm looking at the 3.5KV or the 5KV version). The voltages on pins 4, 5, and 6 are the same with either switch position. I could use some guidance on how to proceed. Should I change the value of R55 so that the voltage on U3 pin 1 is at least 1.2/1.3V? Or should I replace U3? Another angle?
sm_ycv40_M581-7.10.pdf
