What Enzo said ^^^^^^^ as well as the relays K1 & K2 showing their pin numbers. You'd sort of have to have a data sheet on the relays to make sense of those.
Hot rod deluxe RevA channel switching
It is difficult to get on the relay pins to take readings. But every relay pin connects to something nearby, like a resistor or something. SO put your meter probes THERE. They don't have tp be right on the relay.Education is what you're left with after you have forgotten what you have learned.
Testing question: I’m going over some of the test points on the schematic (had to enlarge it since my eyesight isn’t too good).
Ovals are AC, right? What about an oval with an expected mV reading? For example TPS 14, 15 expect 66mV on an AC scale?
Im using an old Sears DVM (not auto-ranging), my AC scale doesn’t seem to include mV.
Goofy Question, enlighten me please.
Originally posted by Oldmactech View PostTesting question: I’m going over some of the test points on the schematic (had to enlarge it since my eyesight isn’t too good).
- Likes 1
While I had a Fender Hot Rod DeVille 410 open, I looked at the two relays K1 & K2, both Omron parts, and they had the pin-out/schematic diagram silkscreened on the top of the relay. I took photos of those, and parked them here, just for reference.
Ok so I’m back with some TP readings. Many of these are not close to what should be so I am minority concerned my old Sears DVM is broken but here goes.
(all taken with the amp on and in the state called for on the schematic) Drive engaged, pots at 50% etc. expected reading is listed first, actual after.
TP 2 R4 1.8mv 0 (pretty loud pop when probing)
TP 3 C1 +1.72v 0 (tested 3.0 at one point recently)
TP 4 R41 13.0mv 0 (hums when probed)
TP 5 R11 252mv 0 (hums, previously tested 442VAC)
TP6 (Incorrect, measured R10 accidentally)
TP7 R8 33mV 0
TP8 R16 850mV 0
TP 9 C8 1.72 mV .90-.150 and wanders.
TP10 R20 580mV 0
TP11 R22 13.3v 440VAC
TP12 R21 1.72 1.74
TP13 R28 20v 0
Tp14 R28 66mV 0
TP15 C12 66mV 0
TP 16 R48 39.mV 0
TP 17 Op amp U1 pin 7 1.28 VAC 0
TP 18 R51 1.14VAC 0
Despite these odd readings, clean channel works as advertised.
Guidance is greatly appreciated.
Are you putting in 4mV 1Khz signal at input jack #1 as specified on schematic? Can you measure it with your meter?
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by Oldmactech View PostNo, I don’t have a signal generator. Is there a way to do that without one?
