Converting Marshall 6101 from 220 to 110v?
  • Converting Marshall 6101 from 220 to 110v?
    Does anyone know if a Marshall 30th anniversary 6101 can be converted to 110v? This one doesn’t have the switch in the back. Can the 2 primary windings that are now in series be wired in parallel for 110v use?
    Looks like you can. Click image for larger version
Name:	Screenshot 2020-07-29 at 14.18.40.png
ID:	910175 Don't get the phasing wrong!
    Support for Fender, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
      Thanks Jon!
      can you tell if this sounds correct?
      I would attach the brown to the other end of the top winding opposite the blue wire and move the other wire on the lower winding to the blue one.
        If you avoud moving the brown and blue wires from the terminals they’re currently connected to, then you can’t get their polarities wrong.
          Leave the brown and blue where they are.
          split the winding connection. Click image for larger version
Name:	Screenshot 2020-07-29 at 15.59.12.png
            Thanks for this information. Now i have to see if I can remove the little board directly over the PT without having to remove the big power tube board and the one above that. I had a broken solder joint on one of the filter caps on the big board earlier and all 3 boards were out. I would hate to have to through that again.
