Hey all, I'm stuck on this repair, this a 3 channel head with all the bells and whistles. I'm getting faint, ugly sound out of the speakers when everything is dimed.
Here's what I've determined:
-The preamp out does indeed provide a good sound to an external power amp, so everything before the jack is good.(that jack is on the bottom left of page 5)
-Bridging the pre-out/power in with a 1/4" cable doesnt fix it, same with fx loop jumper
-Voltages on el34s are where they should be, but of note, the heater string reads 6.4VAC on one side , between pins 2 and 7, and 6.2VAC on the other
-LTPI voltages seem good, plate resistors are dropping voltages ok and I switched that tube out to make sure that wasn't the issue
So everything is fine after the preamp out switching jack, that I know.
My first problem is reading that damn schematic. I'm getting lost just following the signal flow after the preamp out jack.
Beyond that, I feel that the problem lies between the pre-out jack, and the PI entrance, but again, I'm not sure what exactly is between those points, and even then, I'm not sure what I'm looking for, or how to troubleshoot what I assume to be a bunch of possible TL072 failures.
ycs100h2__service_manual.pdf
