Reassembled a Peavey amp after replacing power transformer. Works fine, sounds a bit wonky, brittle.. I took a pic of the speaker wiring connection and put it back that way. Yesterday, I reversed the polarity and seems to sound better. I know this amp was apart before so before I assume the polarity was correct, is there a way to test without having to disassemble again. I know how to test the speaker but not the speaker cables.
Determining speaker polarity
Plug the speaker lead into the speaker cab. Use a PP3 9volt small battery and the speaker cone should push out from the magnet if the positive battery terminal goes to the tip of the jack plug and the negative to the sleeve.
Test momentarily and observe the direction of the cone.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
- Likes 1
If it's a single speaker amp, polarity to the speaker should have no noticeable affect on the sound.
Unless one of the speaker terminals is connected to the speaker frame, that could create some potential issues.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by Oldmactech View PostYesterday, I reversed the polarity and seems to sound better
Your perception of the sound is all that matters. caveat: there is an argument that LF energy, like kick drum wavefronts, are sensibly different when the phase is reversed. You would need to calculate (or measure) the phase relationship between the input jack and the speaker jack. Having done that, there's no real guarantee that a (near) zero phase between input and output really is the version of 'better' that you hear.If it still won't get loud enough, it's probably broken. - Steve Conner
- Likes 1
E.g. a 400Hz sound wave reverses phase every 17"of increased distance from speaker. Different frequencies reverse phase at different distances.Last edited by Helmholtz; 12-01-2020, 07:16 PM.- Own Opinions Only -
Generally speaking, though there are a few exceptions, chassis ground is speaker ground. So, if you want to know which amp wire goes to speaker ground, use your meter and see which wire is at chassis ground potential.Last edited by The Dude; 12-01-2020, 10:51 PM."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
- Likes 1
Neither Groove nor Ruby make their own tubes. Ruby is a large seller, I used them for years. But they don't hide the fact their tubes are JJ or Sovtek or EH or SHuagang..Groove tube as well sells you 6L6s that are really Sovteks. it isn't secret.Education is what you're left with after you have forgotten what you have learned.
