Back again with another transistor snafu.
Amp is Ampeg B5R. It is stuck in 'Clean' channel. Unable to change into 'Overdrive' channel.
I've attached both full schematics as well as screenshots of what I believe to be the problematic/relevant sections as the schematics are huge.
Neither front panel switch nor foot switch are able to change channels.
Originally I suspected Q1:B. It is one quarter of a MPQ222A, a 14-pin TO-116 with 4 NPN transistors inside, responsible for the complex channel switching in this amp.
I took the MPQ222A out of circuit and tested it on a signature tracer - and it seemed to check out fine.
I installed the chip back in the amp and powered on to do further testing - and the channel switching now worked! For a few switches anyways, before ceasing to function again.
I'm not sure why it worked for a few switches intermittently. I pulled out the board again to inspect for bad joints but all looks fine.
I'm having trouble understanding how this switching system works, thus having trouble effectively troubleshooting it. \
Voltages of Q1:B:
Clean Channel mode (Channel Select Switch Out)
B: .011VDC
E: .007VDC
C: 14.3VDC
Overdrive Channel mode (Channel Select switch pushed in)
Q1:B
B: .020VDC
E: .003VDC
C: 14.3VDC
If I manually bridge collector and base, the amp switches into Overdrive channel and seems to be fine.
I think I should try substituting the MPQ222A with discrete NPN's. I'm having trouble figuring out what will be a suitable replacement for switching purposes.
Any help with a method of troubleshooting this or just a nudge in the right direction is very appreciated.
Thank you in advance for any help.
Voltages of Q1:B:
B: .011VDC
E: .007VDC
C: 14.3VDC
Q1:B
B: .020VDC
E: .003VDC
C: 14.3VDC
