120v, 2 power tubes installed, no red plating, but same hum and no output. Mid-range control is only one that has any affect on hum. And hum pot and wiring were removed by previous owner.
70s Ampeg V4B Blows Fuses
Originally posted by ca7922303 View PostAny thoughts on where to go to get output? Appreciate the help.
If not you can try tracing the signal with your meter set to AC Volts.
Here are some likely causes: http://www.geofex.com/ampdbug/onlyhiss.htm
Originally posted by ca7922303 View Post120v, 2 power tubes installed, no red plating, but same hum and no output. Mid-range control is only one that has any affect on hum. And hum pot and wiring were removed by previous owner.
Hum at mid-range control affects arises due to ferrite core L101 in mid-range eq. It's normal.
Instead removed hum pot, install hum balance with resistor.
It's All Over Now
- Likes 1
If that isn't the issue, I would then eliminate the possibility of a bad tube causing hum. No need to make the repair anymore difficult than it needs to be. Start by pulling V1, and see if the hum goes away. If so, try another 12AX7 and see if that fixes it. If the hum is still there, pull V2 and repeat the same steps. Then go onto V3 if you need to, and so on.If I have a 50% chance of guessing the right answer, I guess wrong 80% of the time.
- Likes 1
Agree with SoulFetish, if someone removed the hum pot circuit, they probably added resistors to replace it.
Solve the 'no output' problem first, maybe you will get lucky and it will fix the hum too. If not, you can chase the hum later.
The 'ext. amp' jacks on the back can be used as either a preamp out, or a power amp in. You can use it to find out if you have a preamp problem or a power amp problem.
Plug a signal into the 'ext.amp' jack. Do you hear sound now? If so, the power amp is ok.
Now plug your signal back in to the normal input. Use another cable to connect the 'ext.amp' jack into the input of some other working amplifier. Do you hear sound?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Had you found a burnt resistor around one of the preamp tubes earlier?
Originally posted by g1 View PostWhatever you smelt around the 6K11 probably got burnt and will have to be dealt with as well.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
His power amp is working if he puts signal into the 'ext.amp' jack, so 12AU7 V4 is working ok. (post #97)
The problem must be before the 'ext. amp' jack.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by ca7922303 View PostI changed preamp tubes around,not the tubes.
If there is no signal from either channel (one or two) for test, replace the tube V3 (12DW7) first and then V201 (6K11).
Since signal passes through the ext. amp jack, most likely defect is in mid eq tube circuit V201 (6K11)
Question
How much is voltages on the cathodes ...
V3 (12DW7) pin3, pin8
V201 (6K11) pin3, pin4, pin6It's All Over Now
- Likes 1
