Originally posted by g1
View Post
70s Ampeg V4B Blows Fuses
Originally posted by g1 View PostCheck both sides of D6 for DC volts with unit powered up and standby switch in 'play' position.
Does this amp have a 3 prong plug installed? Where do you connect your black probe as a ground when checking DC volts?
1 Photo
Leave a comment:
Leave a comment:
Sorry, I meant D5.
Leave a comment:
Originally posted by g1 View PostCheck diode D10. Unit turned off, meter on diode check function, check then reverse probes and check the other way.
Leave a comment:
Originally posted by g1 View PostWell it doesn't make much sense for the voltage to be staying so high all the way to the front like that, tubes along the way should still be running which would reduce the voltages somewhat.
Could be that the break is along the ground line rather than the B+ line.
Check diode D10. Unit turned off, meter on diode check function, check then reverse probes and check the other way.4 Photos
Leave a comment:
Originally posted by ca7922303 View PostI can see they go to R52,53, I'm just wondering if the cap they connect to could be bad because of the loud pop I heard the other day @ 120v.
We agreed "Let's go step by step"#145
And you started the old way again.
Dear friend. For these 155 posts in the story you spun "70s Ampeg V4B Blows Fuses", even a small child would have already learned something.
But you are obviously bored.
In addition to the good will to philosophize and spin the portal, do you have an idea of what you want from yourself and what you want from members who are trying to help you.
If there's nothing to do, don't do it here.
And return back to the post #145
Inform about results of what you done about questions asked in post.
Leave a comment:
Check diode D10 (edit typo, should be D5). Unit turned off, meter on diode check function, check then reverse probes and check the other way.Last edited by g1; 04-27-2021, 06:36 PM.
Leave a comment:
Looks t my eyes like they are wired directly to the main filter cap can right next to them.
Leave a comment:
Originally posted by g1 View PostIf they measure good, then they are probably good. Instead of mounting them on the circuit board, they run wires to them and mount them on that cap. Electronically it is the same. They run hot so it helps keep heat off the circuit board.
The voltage from the power supply goes through a chain of resistors. Somewhere along the chain it broke, you heard the pop, and now the voltage isn't getting to some of the tubes any more. Each resistor in the chain will drop a bit of voltage, but somewhere along the line now it will all of a sudden go to zero. That will be the break. It could be a bad resistor or a bad connection.
The order of the chain is R53,R52,R51.
If you say you are measuring 570V at both sides of each of R53 and R52 in the photo, then check both sides of R51.
Leave a comment:
Leave a comment:
Originally posted by vintagekiki View PostCompare the layout of the V4B in front of you with the schematics
Look where all the wires are going from R52, R53
Leave a comment:
Leave a comment:
